Naviate Structure October Release 2023.1.13 and 2024.6.1
Release news for Naviate Structure. Highlights includes  new download from MySymetri, updates to New Rebar Numbering and more.
Check for updates
Get notified if there are newer versions available for download. When Naviate is started there is a check if there are newer versions available of your installed applications.
  • until next startup – Remind me next time Revit/Naviate is started (default).
  • 1 day – Remind me when starting Revit/Naviate next day.
  • 1 week - Remind me when starting Revit/Naviate next week.
  • 1 month - Remind me when starting Revit/Naviate next month.
  • until next version – Don’t remind me until a newer version has been released.
Updated Symetri login
If you have rights to manage licenses on My Symetri there is now an option to create a license file including Single user licenses that you can copy to machine not connected to internet.
A zip-file is generated and downloaded by the browser. Extract the included license files and copy them to the %appdata%\Symetri\Licensing folder on the machine you want to use off-line when you are logged in as the user specified when creating the license file.
New Rebar Numbering. Only for 2024.6.1
Now you can number the straight bars using their cut length.
In New Rebar Numbering Configuration, you can choose to use Numbering method, Number Strength bars by Cut Length:
You can activate the "Number by Cut Length" feature for each partition individually. When numbering is applied, straight rebars will be assigned numbers based on their cut length.
Tip! For additional information about New Rebar Numbering feature, see: Configure Rebar Numbering
Updated Symetri licensing
  • Only 2024.6.1 New Rebar Numbering: Fixed issues when grouping rebars in projects using imperial units.
