Naviate Zero October Release 2023.1.13 and 24.6.1
Release news for Naviate Zero. Highlights include new download from MySymetri and updates to EPD PDF download, Domain Filters, Automatic Mapping of Units, Support for Imperial Units in Calculation and more.
Check for updates
Get notified if there are newer versions available for download. When Naviate is started there is a check if there are newer versions available of your installed applications.
Updated Symetri login
Updated Symetri licensing
EPD PDF Download
This feature allows you to easily download Environmental Product Declarations (EPDs) in PDF format.
This is accessible through the Details feature of each resource in apply resources. EPDs are comprehensive documents that provide detailed information about a product's environmental impact throughout its lifecycle, from raw material extraction to end-of-life disposal. By downloading these PDFs, you can access valuable data on factors such as greenhouse gas emissions, energy consumption, water usage, and waste generation.
Improved UI readability
Tables and headers have been updated in the Apply resources and Calculation window, making it more readable.
Double click Apply Resources
Apply Resources now supports assigning resources by double clicking on the desired resource. Multiple types can be updated at once if they are of the same resource. Double click will apply the resource to all checked types.
Naviate Zero now supports calculations in Imperial units. The units are specified in the Zero Settings.
When the Zero calculation schedule is created, it will now always include both imperial and metric units.
Apply Resource warning
Users are now warned if they are trying to apply a resource to a type with materials and clones with resources assigned. This would earlier cause the resources assigned to the material and clones to be removed without a warning. Users can choose not to show these warnings again. Choosing Do not ask again will be valid for one Revit session.
Domain Filters
Filtering in Apply resources can now be further customized by adding a hard filter based on domains such as TRACI, CML, PEF or GCR. To use it, select the domains you wish to use in Apply Resources. For example, checking CML will filter out all EPDs connected to European and global data.
Automatic unit mapping now enables the filtering of resources according to the unit of the selected Type. When Automatic mapping is activated, selecting one or more Types will automatically check the corresponding units within the Unit filter. This speeds up finding suitable resources for to use with the selected Revit types.
- Apply Resources - Apply resource window no longer resets filters if you refresh the window.
- Apply Resources - Selection of elements via Apply Resources now filters elements with correct phases.
- Apply Resources - Selection of elements via Apply Resources now filters elements with the correct Exclude element status.
- Calculation - Selection of elements via the Calculation window now filters elements with the correct Exclude element status.
