Naviate Zero May release news 2025.2
Release news for Naviate Zero. Highlights include five new features: Calculate View Only, Export Calculation, Apply Resources Unit Update, Add Resource Comments, and Resource Translation. Updates have also been made to Export Resources Comments to OCL, Calculation Performance, Manage Assemblies Performance, Solving Data Conflicts, and What's New Pop-up.
What's New Pop-up
NEW! Calculate View Only
Calculations now allow calculations to be performed using only the elements visible in the currently active view. While the calculation window keeps its familiar appearance, it exclusively reflects data from the selected view. Additionally, any exports started from the calculation window will include only the elements present in that view, enabling more targeted analysis and streamlined reporting.
NEW! Export Calculation
A new export option has been added, allowing users to download calculation results as a CSV file. The exported data follows a consistent format, regardless of the distribution grouping used for embodied carbon, ensuring clarity and ease of use for further analysis or reporting.
NEW! Apply Resources Unit Update
A new feature has been implemented to address unit mismatch errors when applying resources. Users can now efficiently manage and resolve multiple unit discrepancies simultaneously, ensuring greater accuracy and consistency in resource application across the project.
NEW! Add Resource Comments
The Apply Resources feature has been updated to support the inclusion of Resource Comments. Each comment is stored to a dedicated Type parameter of the specific Revit Family Type. This allows users to capture and communicate important context—such as status updates, uncertainties about the selected EPD, or other project-relevant notes. These comments are also included in the export to One-click LCA, ensuring continuity of information throughout the workflow.
NEW! Resource Translation
Project settings have been enhanced to support Resource translations. Users can now specify the preferred language for displaying the list of Resources within the Apply Resources interface. Additionally, users can define the language to be used when saving or exporting data. If a Resource lacks a translation in the selected language, English will be applied as the default fallback.
Export Resource Comments to OCL
The export to OCL has been updated to include the new Resource Comments. This feature makes it possible to transfer important communication between the Revit model and OCL.
Calculation Performance Enhancement
We've improved the calculation engine to significantly reduce processing times. Users will now experience faster results, improving overall efficiency and responsiveness during project analysis.
Manage Assemblies Performance Enhancement
The performance of the Assembly creation process has been improved, resulting in quicker response times and a more efficient user experience.
- Apply resources: Fixed bug in search for EPD number and full name.
- Apply resources: Fixed Revit crashes when removing an applied resource on Naviate Filters.
- Settings: Fixed how parameters are being created when settings are saved.
- Settings: Fixed export of settings, which previously was not exporting all settings.
- Calculation: Fixed calculation showing empty when NVExclude was not created as an instance parameter in the model.
- Manage Assemblies:
- Fixed Save and Publish buttons not clickable when creating or editing assemblies.
- Fixed Dashboard showing incorrect count of assemblies.
- Fixed resources keep appearing on top on resource page.
- Fixed resource filter, duplicating resources multiple times.
- Fixed message displayed when saving an assembly.
- Fixed required "Available Areas" field allowing assembly creation even when left empty.
- Fixed Quantity resetting while duplicating resource with quantity and thickness.
- Removed redundant clear option in Resource filters.
- Fixed incorrect resource type displayed after applying filters in Add Resource.
- Fixed Reference number not appearing in Assembly details.
- Fixed dropdown menu for unit selection not being able to be closed properly and required two clicks to open.
- Fixed adding multiple countries in "Available Area" expanding the window horizontally, causing layout issues.
- Fixed missing warning when switching accounts during assembly creation, leading to partial data loss.
- Fixed resource category search not displaying results for uppercase input.
- Fixed preselection of some resources when creating assemblies.
- Fixed submitting GWP without changes resulting in a different value, then causes a calculation error.
- Fixed the country list and removed duplicates.
- Renamed Edit button in Edit Assembly to Republish.
- Fixed refreshing page changing which account is being used.
