Don't miss out
Want to see the latest Naviate for Civil 3D General news?
Updates in Traffic. News include new features Sign Elevation Check and more.
Changes are available in 2023.2 and 2021.22
A new feature that can evaluate distance and elevation for signs on a sign holder in relation to set values or a selected Rule-file. The feature can then move the sign holder in horizontal and the sign in elevation to fulfill the rules.
Move Sign, Move Sign Holder, Erase Sign, Erase Sign Holder and Edit Sign Attributes added as commands on the Ribbon.
A portal can now be built from a 3D-block that is arrayed to match the set elevation of the portal. This can for instance be used to create a truss portal.
This can be used to create a combination of portal legs and beam.
Section block for the Sign Holder can now adapt to the height of the sign holder.
If the sign selected is a 3D-block, then that block is rotated to be placed correctly in all views on the sign holder.
Can now use Formulas
