Naviate Structure March Release 2022.1.7
Updates in Structure. Highlights includes improvements to Openings to Trim.
Changes available in version 2022.1.7
To be able to update to version 2022.1.7, you need to manually download and install the update from our download page. Remember to update Naviate Help and Naviate Accelerate to at least 22.1.6 as well.
All installed applications must be updated to 22.1.6 or 22.1.7. Except Naviate Rebar Extension that has no update anymore. Find more information here
Openings / Trim to opening
Renamed from Openings to Trim to opening and improved workflow to be able to trim rebar around the opening in any view.
We have Renamed the tool from Openings to Trim to opening, and improved performance and user experience by allowing you to use a tool from any view.
We have made the following improvements:
- You are now able to trim/split rebar around the opening in any view, just by selecting an opening in the wall, floor, or slab.
- After the trim, reinforcement is constrained to opening faces and will adjust if the opening size is changed or if the opening is slightly moved.
- You are now able to trim rebar around circular openings.
