Naviate Simple BIM release 2022.3.1
Updates in Naviate Simple BIM. New feature Groups and improvements to Bimsheet, Validation, Table Palette, 3D Window, IFC Export and Location Tools.
Updates available in version 2022.3.1
New! Groups
Option added for using parent groups to limit the objects that can be assigned to manual child groups. First you add objects to the parent group, and after its child groups will only accept objects that belong to the parent group.
Bimsheet
Support for column references added to SUMIF, SUMIFS, COUNTIF and COUNTIFS. Column references are used in Excel formulas to reference all cells in a column, for example the formula '=SUMIF(B:B;F4;C:C)' matches all cells in column B and calculates the sum from cells in column C. This is handy when you don't know the number of rows in advance, which is most often the case when you extract data from a model.
Validation
Performance improvements.
Table Palette
Better support for Yes/No (boolean) values. Values are now shown using a checkbox in the table.
3D Window
Usability and stability improvements.
IFC Export
Improved support for exporting shared geometries.
Location Tools
Improved assembly splitting logic.
Improved process for defining multiple overlapping location systems in one model.
Added tolerance for geometry related issue in location prisms.
- Template: Bug fixed in setting the status of objects to not-decided-yet when applying the template from a script
- Bimsheet: Bug fixed in using more than two filter criteria for text properties
- Bimsheet: Bug fixed in persisting filters for non-text properties
- Template: Bug fixed in adding empty groups multiple times. A new empty group was created each time even if a group with the same name already existed in the same group category
- IFC Export: Bug fixed in exporting properties with invalid metadata. Instead of the whole export failing, information about the problematic properties is written into the log
- 3D Window: Bug fixed in the visibility of newly modelled objects. Templates: Bug fixed in restoring the name of 'Ungrouped Groups' when creating groups with a template
