Naviate Simple BIM release 2022.2.1
Take your BIM workflow to a new level with Set Default Property, Delete Selected Objects and Appearance Editor.
Naviate Simple BIM has new features! Read below for an overview and next steps.
Allows setting the default property used for object classes in Naviate Simple BIM menu. Previously, it has only been possible to set the default property manually in the properties palette.
Improved deleting of containers and spaces.
Appearance Editor
You can now set colours for assemblies.
- IFC Import: Bug fixed in reading object appearance, where some geometries was skipped at import.
- BIM sheet: Bug fixed in reading where BIM sheet have multiple object classes in one table. Previously only the common properties were always shown, now the Show Only Common Properties setting works.
- Table palette: Bug fixed in using characters in tab names that are not allowed in Excel worksheet names. These characters are now automatically removed when adding tabs from groups and when opening stored tables or workspaces.
- IFC Export: Bug fixed in exporting text values that contain both Unicode characters and the backslash (\) character. In this case the backslash characters were quadrupled in the IFC file when they should be doubled.
