Release news Naviate for Cloud solutions
Naviate Simple BIM 11.0.6
Updates in Naviate Simple BIM 11.0.6 Highlights includes several improvements Dataflow, language support for Portuguese-Brazilian and several other enhancements and bugfixes done.
These release notes included in Naviate Simple BIM 11.0.6
Enhancement
Simple BIM 11.0 SR6 (10.12.2025)
  • Finalized Portuguese-Brazilian translation
  • Separator updated: empty spaces removed + separator is editable
    • Combine Object Properties
  • Performance improvements in opening dataflows with a lot of steps and/or configuration options.
  • Copy Property Values -tool: Option for copying from child group added.
  • Improvements to geometry operations in special cases
  • Properties palette: Link added to documentation of filter options
  • 3D palette: Link added to documentation of 3D navigation
  • Added automatically fixing invalid geometric representation contexts
Simple BIM 11.0 SR5 (4.11.2025)
  • Improved ‘design echo’. The user interface now better automatically and consistently updates to show changes made to the model by dataflows. This helps to better understand the effect of running dataflows and individual dataflow steps.
  • Dataflows: Dynamic titles added to ‘Merge IFC File’ and ‘Round Object Property Value’
  • Dataflows: Updates to configuration for easier use and understanding to ‘Round Object Property Value’, ‘Inherit Properties from Assemblies to Parts’, ‘Derive surface Objects for Space Floor’, ‘Derive surface Objects for Space Wall’
  • Dataflows: Group hierarchy updated (Simplebim category removed) to ‘Add Common Object Groups’, ‘Exclude Duplicate Objects’, ‘Derive surface Objects for Space Floor’,  ‘Derive surface Objects for Space Walls’, ‘Add Location Prisms’ and ‘Merge IFC File’
  • Dataflows: Added option to copy one or two values from nearby space to create Space Identity property to ‘Add Location Using Nearby Space’
  • Dataflows: Added option to activate/deactivate splitting and option to copy one or multiple values from location prisms to objects to ‘Add Location Using Prisms (Optional Split)’
  • Dataflows: Target limited to Space only for ‘Add Location Using Nearby Space’, ‘Derive surface Objects for Space Wall’ and  ‘Derive surface Objects for Space Floor’
  • Improved drag&drop for dataflow steps. A menu is displayed at drop for choosing the action (move/duplicate) and target (step/section/steps in section)
  • Option added for adding a new dataflow section header above the selected step.
  • Improved handling of invalid containers in IFC import: IfcDistributionPort is now filtered out from containment as well as containers containing themselves (recursion)
  • Import support for IfcPropertyEnumeratedValue: If the value is not a list it is converted to IfcPropertySingleValue at import
  • IFC export protected against invalid recursive containment and such references are also dropped at import.
  • Missing ‘copy from facility’ -option added to Copy Property Values -tool
  • Some memory leaks fixed in dataflow editing that could cause an application crash when Simplebim was used for a long time without closing.
  • Add or Replace Group -tool: Sime illegal configuration combinations removed.
  • Objects -palette: bug fixed in adding ungrouped groups. The new ungrouped group did not always become visible before a refresh.
  • Objects -palette: bug fixed that caused the application to crash when a new rule based group was added without defining a rule.
  • Groups: bug fixed in using yes/no rules for rule based group
  • Groups: application crash fixed in saving complex rule based groups as a group template file.
  • Table palette: bug fixed that prevented excluded objects from being selected in Trimmer mode
  • Properties palette: bug fixed in updating the display after adding properties to multiple object classes using a dataflow.
  • Expression editor: bug fixed using properties that contain numbers in the name as variables
  • Stability improvements: the application is much less likely to crash
  • Crash exporting invalid containers fixed in IFC export
  • Bug fixed that sometimes caused the list of selected object classes to be lost when using object classes as a target in a tool/dataflow configuration
  • Bug fixed in using properties that don’t exist in the current model in queries.
  • Several bugs fixed in geometry handling e.g. splitting that caused the geometry to break in special cases
  • Objects -palette: Bug fixed in ‘Show Empty Object Classes’ option
  • Bug fixed in auto-saving dataflow when using shared dataflows folder. Previously the autosave file was written to the shared folder overwriting the autosave file of other users. Now the autosave file is always written to the default dataflows folder in each user’s own profile.
