Release news Naviate for Cloud solutions
Naviate Simple BIM 11.0.5
Updates in Naviate Simple BIM 11.0.5 Highlights includes new features Dataflow Sections, language preview Portuguese-Brazilian and several enhancements and bugfixes done.
These release notes include Naviate Simple BIM 11.0.5
Instructions for finding functionality that has moved or changed in Simplebim 11
New Features
Simple BIM 11.0 SR4 (1.10.2025)
- Dataflow Sections: Dataflows can now be organized into sections for clarity. Sections can be run, collapsed/expanded, enabled/disabled, moved, duplicated and deleted.
- The folder for My Dataflows can be changed from the application settings. The My Templates folder for legacy Excel templates can be changed from the same place.
- Portuguese-Brazilian translation (preview)
Enhancement
- Dynamic titles added to multiple installed dataflows
- Exclude Object Properties dataflow: name updated (previous name: Clean Object Properties)
- Dataflow steps and sections are now highlighted when moving over them with the mouse.
- Dataflow step and section selection and name editing is improved to work like selecting and renaming files in Windows Explorer, including Shift and Ctrl selections.
- The menu bar of the Dataflow palette is redesigned for faster access to common functionality
- The progress reporting for running dataflows, sections and steps has been improved.
- The save button in the menu bar of the Dataflow palette now shows if the current dataflow has changed.
- When target selection in tools and dataflow configurations is limited to object class(es) the Custom option is no longer available.
- IfcSurfaceFeature in IFC4 models is now supported
- Significant performance improvement in Convert Objects -tool
- Alignment and Referent added to All -selection
- Add common Object Groups dataflow: configuration fixed
- Add Basic Quantities dataflow: deleting temporary groups fixed, area measures to building element part object class added
- Add or Modify YesNo Property dataflow: option not to set Value fixed
- Add Location Using Prisms (Optional Split) dataflow: option to use any object class as a location prisms fixed
- Add-on exporters (like Catenda HUB and Trimble Connect) don't any more disappear from the ribbon after the first export.
- Bug fixed in generating derived objects with quantity calculation tools with the 'Derive Objects' operation selection.
- Bug fixed in shadow area calculation for objects rotated relative to the shadow plane.
- Calculate Quantities: Surface Areas -tool. Bug fixed in generating net side areas for complex objects.
- Bug fixed merging models that have different angle units and use IfcTrimmedCurve
- Optimize Geometry -tool. Bug fixed in converting objects to boxes when objects have unusual geometry transformations.
- Bug fixed in splitting geometries: In rare cases split geometries could become hollow, i.e. not completely enclosed.
- Bug fixed in adding building storeys from the Containment -palette: sometimes the newly added building storey was not immediately visible in the palette.
- Bug fixed in Convert Objects -tool: the tool was losing 2D geometries in the conversion.
- Bug fixed in Convert Objects -tool: the geometry of the converted objects was misplaced if the original object was a building element proxy containing other building element proxy objects.
- Bug fixed in writing predefined type attribute of Space objects to IFC4.3 models
- Bug fixed in reading IfcProxy objects (there were no issues with IfcBuildingElementProxy)
- Bug fixed in using IfcFacility in the containment structure
- Bug fixed in report header when opening a new model after running a dataflow
- Bug fixed in displaying geometry of objects that are far away from the origin in the 3D window when the length unit of the model was meters/feet. This did not affect the actual geometry, for example splitting, quantity calculation or IFC export.
