Naviate Road 2024.1 release
Updates in Naviate Road. New features includes Units and Templates. Improvements include shape to Solid, Link to solid, Add bus stop and Volumes in Intervals.
Changes are available in 2024.1 & 2023.11
Units and Templates
In this version we have changed how Naviate handles default values and templates. Default values now depends on the template that you are using. When using functions that require styles, the function itself will import the required styles. To learn more about how this works, please see this blog post.
Shape to Solid, Link to Solid
Now has updated default values for use in an Imperial template.
Add Bus Stop
Has been renamed to Add Widening.
At startup you can select between Edit table, Open last report, Open clean report, or Open new report. You can also set auto-recompute at start up (set to No speeds up opening).
A progress bar has been added to the recompute process. Also, reporting tools are disabled unless a recompute as been done.
Creating Hatches and Meshes from the calculations have been speeded up, the process is now between five and ten times faster in our tests.
- Import Assembly Fixed an issue where the Code Set Style was always imported.
- Export Corridor Fixed an issue where the translation file was not stored.
