Naviate Road 2023.2 Release
Updates in Naviate Road. News and improvements include; Check Profile Tangency, Create Profile Views from Multiple Alignments, PVIs to Corridor and Create Reverse Profile.
Naviate Road
Changes are available in 2023.2 and 2021.22
New feature. Check Profile Tangency
A command to check tangency in a profile line and highlights where the issues are.
New feature. Create Profile Views from Multiple Alignments
A tool to create multiple Profile Views from Multiple Alignments at the same time. The command can create a Finished Ground Profile in each profile view as well as create Stacked profiles.
New feature. PVIs to Corridor
The command adds all PVIs from profiles to a corridor as manual stations
New feature. Create Reverse Profile
A command to reverse a profile in a Profile View
Stepped Profile
Now with the option of adding all PVIs to the corridor, by starting the new command PVIs to Corridor. Stepped Profile can now select the closest node when selecting start/end point
Import Assembly
You can now import the code set style applied to the assembly imported, and can set that assembly style to the Create Corridor-commands in the drawing.
