Naviate Road 2022.1 Release
Updates in Naviate Road. News and improvements include; Solids from Shape, Navisworks Views, Subtract Solid and more.
Naviate Road
Changes are available in 2022.1
Added toggle button "Set Property" where you can select a property in the current Property Set and then enter the value to set.
Updated with the option to subtract from multiple solids.
Now exports views with Sectioning (Slicing plane) in Navisworks.
Commands for Update Assembly and Update Corridor Settings is now possible to script run in Autodesk Batch Save Utility.
Fixed an issue where Write to File doesn't warn if the file is open.
Fixed an issue where the label on the second to last station is placed wrongly.
Update Featureline Label Group
Fixed and issue where the command adds labels to all corridors in the drawing.
Updated to work better with large data sets.
Fixed an issue where shapes are not created if points are on the same X/Y.
Fixed an issue where the command fails if the surface style doesn't display Border.
