Naviate Rebar October Release 2023.1.13 and 2024.6.1
Release news for Naviate Rebar. Highlights includes new download from MySymetri and the new feature Rebar Collision.
New! Rebar Collision
Check for collisions (clashes) between rebars in the structural elements. Use Rebar Collision tool to detect any clashes between reinforcement bars and ensure rebars are correctly placed and distributed in the structure.
The main features of Rebar Collision are:
- You can check for collision either on preselected structural elements with reinforcement or directly on the selected reinforcement elements themselves.
- Colliding rebars are selected/highlighted in the view and listed in the Rebar Collision report.
- You can double-click a row in the report to zoom to related colliding elements.
- You can define a tolerance value, the minimum overlap length between rebars that will be recognized as a collision.
- You can define the minimum size of bar diameter. Bars of smaller diameters will be excluded from the analysis for collision.
- Rebars that collide have value "colliding" for the NVRebarCollision parameter, while those without clashes are marked as "not colliding."
- The NVRebarCollisionIncidences parameter allows you to identify the specific rebars within a set that are colliding.
Tip! Use NVRebarCollision parameter with the Color Rebar feature to easily identify colliding and non-colliding rebars in the view.
Check for updates
Get notified if there are newer versions available for download. When Naviate is started there is a check if there are newer versions available of your installed applications.
Updated Symetri login
Updated Symetri licensing
