Naviate Rebar June Release 2023.1.12
Release news for Naviate Rebar. Highlights includes the new feature Transfer Settings, update to Wall and fixes.
New! Transfer Setting
Transfer named settings from all Naviate Rebar tools between projects.
Transfer settings is a new feature that allows you to export and import settings from all Rebar (RE) tools across projects.
The main features of Transfer Settings are
  • You can export named settings from all RE tools to an XML file.
  • Specify the name of the export file and choose a location on your disk to save the exported file.
  • Import one or more XML files containing settings from previous exports.
  • You can preview the settings before importing; the preview displays the settings and their respective tools.
  • If imported settings reference elements that do not exist in the project, those settings cannot be imported, and an info message will be displayed.
  • If duplicate named settings are found in both the project and the import file, you will be prompted to either save them as duplicates or skip the import of the specific setting.
Export settings
Import settings
Wall
Now wall dowels have layout rule maximum spacing, the same as wall main bars.
Wall dowels on all three sides (top, bottom and sides) are generated as rebar sets with a maximum spacing layout rule, ensuring they align with the main bars.
  • Opening: Now you can create opening reinforcement on the wall with a sweep.
  • All features: All features now remember the size and last position of the dialog box after reopening.
  • All features: All features now display the full names for bar types, bar shapes, and hook names.
