Naviate Pipe for Civil 3D 2021.1 Release
Updates in Naviate Pipe (Water & Sewage). Improvements include; Select pipes from Spanning Label, Pipe Subassembly, Import Corridor Settings and more.
Changes are only available in 21.1 and will be made available in 2019 and 2020 in a later version.
Select Pipes from Spanning Labels
Several Naviate commands have been supplemented with support for Spanning Labels. Instead of selecting start and end pipe, you can select a spanning label instead. There is also a Select objects from Spanning label to select the included pipes.
Pipe Subassembly
The Naviate Pipe subassemblies can be used for Pressure Pipe networks as well, and this has been updated to include fittings and appurtenances as well.
