Naviate Pipe 2024.2 release
Updates in Naviate Pipe. Highlights include Modify Single Pipe, Offset in Structure and Modify Multiple Pipes.
Changes are available in 2024.2
Modify Single Pipe
A new command to edit elevation, slope for a single pipe with the option to adjust connected pipes. The dialog can stay open while editing and with the arrow-buttons you can move to the next connected pipe. The Elevation box can handle addition and subtraction so you can both move a pipe end to an absolute elevation as well as a relative value.
Rename Pipes by Structure names
A new command that renames selected pipes or all pipes in a network by what structure the pipe is connected to. The pipes can get optional prefix, interfix or suffixes along with the structure names.
Offset in Structure
Now includes a Reset option. This can be used before a corridor is rebuilt to get a better result.
The command can now handle selection both upstream and downstream along the pipe span.
- Fixed an issue in Modify Multiple Pipes where Pick (Elevation) calculates wrong if the pipe is already below the point selected and Below is used as option again.
- Fixed an issue where Modify Multiple Pipes calculation didn’t skip Null Structures
