Naviate Pipe 2022.3 release
Updates in Naviate Pipe. News and improvements include updates to Pipe from 3DPolyline and Pipe Network to DWG.
Changes are available in 2022.3, 2021.13, 2020.23 and 2019.33
Update Pipe from 3Dpolyline (NvPipeUpdateFromPolyline)
The command always stores the used settings. The command also recognizes the settings used in Offset Pipes directly.
NVPipeNetworkToDWG
This scriptable command has been updated to be able to place the exported objects on a layer from a Property in the Property Set on the pipes. If the property set contains properties called Timestamp and user, this will be automatically populated during export.
The command can now use an Affix-file to rename objects layers with Prefix, Interfix and Suffixes. For more information see the help section.
