Naviate Cloud
Naviate Nebula April 2025
Release news for Naviate Nebula. Highlights includes the features Transfer folders and files with versions history and attributes, Transfer all file version history or current version, Transfer between projects in all regions, Schedule recurring sync transfers, Transfer custom attributes between projecs, Publis Clod workshare Revit models and Backup your project data
Transfer folders and files between BIM 360 and ACC Projects
Transfer folders and files with versions history and attributes from BIM 360 and ACC Project’s to another project on any region of Autodesk Construction Cloud.
Transfer all versions or the current version. Automatically rebuilds the version history in version order in the destination project. Supports syncing versions between scheduled transfers.
Transfer between projects in all regions: US, EU, and APAC.
Schedule transfers between projects to streamline the process of transferring files between teams working in different BIM 360 or ACC Projects. The projects can be on the same hub or different companies' hubs, and between any regions.
Transfer custom attributes between projects
Automatically create custom attributes in the destination project and copy their values per version from the source project. Eliminating manual data entry.
Publish Cloud workshare Revit models as part of the transfer process
Ensure you have the latest work. Capture the latest syncs in the cloud workshare Revit model automatically by publishing any work eligible for publish to a new version and then including it in the transfer.
Backup your project data hosted on other companies' hubs
Don't lose access to your working files on Projects hosted on other companies' ACC Hubs. Streamline transferring your project data to your own ACC Hub frequently to ensure data ownership. Consolidate multiple project data sources into one project, for project closeout or hand-off.
