Naviate MEP May release 3.9
Naviate MEP release. Improvements to Solving Data Conflicts between projects, Naviate What's New Pop-up, Data Sync Relationship Manager and fixes.
Please note: Naviate MEP and Fabrication are now available for Revit 2019 through 2025
What's New Pop-up
Relationship Manager enhances the existing Data Sync command by providing a visual, grid-style interface to manage all Data Sync relationships within the project.
Launched from within the main ‘Detail Data Sync’ dialog, Relationship Manager displays each relationship that exists in the project, with options and actions to manage instances of Data Sync:
- View the 3D Element, 2D Elements, and the Synced Parameters of a Relationship
- Add Synced Parameters to the Relationship
- Delete Synced Parameters from the Relationship
- Select the Elements in the Relationship
- Highlight the Elements in the Relationship
- Delete the Relationship
Relationship Manager is launched from the Data Sync dialog.
Relationship Manager’s User Interface, here displaying two separate Data Sync Relationships in this project.
- Rotate Fitting:
- Fixed issue with command in 2025 version.
- Copy Circuits:
- Resolved a bug where Copy Circuits tool was skipping Panels with Spare/Space circuits in Panel Schedule.
