Naviate MEP March release 3.8
Naviate MEP release. Improvements to Copy Monitor Plus, Rotate Fitting and Fixes.
Please note: Naviate MEP and Fabrication are now available for Revit 2019 through 2025
Copy Monitor Plus
Improved stability of the command, including parameter value reading/writing, matching host Elevation and Level offset, correcting Color Toggles, and adding Color Toggle Key in tooltip.
Enhancement to Copy Monitor Plus improve performance and usability when working with Linked Revit Models:
- Improved Element Matching: CM+ elements now align more precisely with their host's Location, Elevation, and Level Offset.
 - Data Synchronization: Relevant data is automatically copied from the host to the CM+ element for better consistency.
 - Enhanced Color Toggle: Fixed the Color Toggle functionality to correctly map changes in the Link to the corresponding colors.
 - Convenient Color Toggle Key: Added a tooltip with the Color Toggle Key, providing users with a quick and intuitive way to interpret the color mapping.
Rotate Fitting
Added functionality to choose the rotation axis for fittings with four connectors.
With either pre-selection or clicking the tool and then selecting the Pipe or Duct Fitting with four connectors, a dialog will appear, giving you the option to choose the X-axis or Y-axis as the rotation axis.
Added Tools from Naviate Electrical and HVAC
Tools that previously existed in Naviate Electrical and Naviate HVAC & Plumbing have been moved to Naviate MEP:
- Create Circuits – Create circuits by selecting elements and then selecting a panel. Separate circuits will be created for each element and added to the selected Panel. For example, this tool is ideal for circuiting multiple instances of Mechanical Equipment that require dedicated circuits in one action.
 - Data Sync – Synchronize selected parameters between 2D Detail Items and a 3D Family Instance.
 - Snoop Run – The selected MEP run is queried, and its data (including straight lengths, sum of the angles of bends, and assigned System Name) is displayed in a dialog.
- Rotate Fitting
- Resolved an issue with the tool either doing nothing or throwing a Revit error for certain MEP Fittings.
 - Elbow Commands Flip Dimensions
- Resolved issue of setting not being saved after closing the MEP Settings window.
 - Snoop Run
- Length parameter is now just calculated by straight lengths.
 - Copy Monitor Plus
- Resolved an issue with the copied CM+ element not being set to the Active Workset.
