Naviate Landscape 2024.2 release
Updates in Naviate Landscape. Highlights include Object Styles Library, Block Library and Line Style Library.
Changes are available in 2024.12
A new command that creates Blocks, Text and Cogo Points with pre-specified settings. The command reads a list of objects stored as CSV in Naviate Support Folder NVObjectStyles.
Block Library
The command has been updated with a Home-button and now uses PNG-files as thumbnails which improves performance.
Line Style Library
The command can now apply both Pay Item and Property Set automatic to the object when it is created. If multiple Payitems need to be added, these can be separated by a pipe character (|).
The function can now hide all rows in the CSV that contains a dash (-)
Fixed an issue where 3D-Extrude scaled block that are Unitless.
Fixed an issue where Extrude along Path scaled block that are Unitless.
Fixed an issue where Line Style Library added hatches to Mpolygons.
