Don't miss out
Want to see the latest Naviate for Civil 3D General news?
Updates in Naviate Landscape. News and improvements include; 3D Measure, Line Styles, Block Library and more.
Changes are available in 2023.2 and 2021.22
The command now has the option to place an Even number by segment length which means that the number of objects placed will match the length of the path. If an option under Adjust Scale is selected, then the objects will be scaled to match the length of the path.
Select Interval and Direction by Chord Length if the path contains arcs and the objects will be rotated to hit the path both in the start and end.
The command has been updated with multiple new features
Block Library now has the option of Mirror X / Mirror Y when inserting a block
