Naviate Landscape 2022.3 release
Updates in Naviate Landscape. News include the new features Naviate Library, Select objects without Property Set and Activate Auto-Add to Schedule along with updates and improvements.
Changes are available in 2022.3, 2021.13, 2020.23 and 2019.33
Naviate Library (NVBlocks)
A new command that can import blocks from any folder and place the block on a surface and add a property set via Add Property to Line.
Select objects without Property Set (NVSelectObjectsWithoutPropset)
A new command for selecting all objects without a specified Property Set.
Activate Auto-Add to Schedule (NVScheduleAddNewEntriesAuto)
This command activates auto-add on a selected schedule. This will automatically add all new objects to that schedule until the command is run again and auto-add is turned off.
Extrude along line (NVExtrudeDia)
Added the option to Extrude with an Offset to the path.
Rotation is now set to Degree and the Flip option flips around the profiles axis.
The command has also been updated to automatically add information to the property set is Add Property Set is selected.
Extrude along line (NVExtrude)
This legacy command has been fixed so that leaves the original lines intact
