Naviate Landscape 2022.2 release
Updates in Naviate Landscape. News and improvements include; 3D Measure and Extrude.
Changes are available in 2022.1
3D Measure
The feature can now browse for blocks and use both 2D and 3D blocks. By ticking Add Property Set, the command Add Properties to Point can be started, to add a property set to the created objects.
Extrude
The command now has a dialog box with more options for the extrusion, and can browse for a profile block. By ticking Add Property Set, the command Add Properties to Point can be started, to add a property set to the created objects. The command has also been tweaked to work better for short segments.
Plant Data and Data Manager
Fixed an issue where the columns in the dialogue where too narrow, the column size is stored.
Dual Elevation Point
Fixed an issue where NVDualElevationPointReset didn’t reset properly.
