Naviate January Hotfix 2022-1-10
Resolved problem using Naviate with other add-ins.
Previous updates of Naviate 22.1.9 included a version of a common dll file that could cause problems with other add-ins
Addins compability
Previous updates of Naviate 22.1.9 included a version of a common dll file that could cause problems with other add-ins such as:
- Naviate Core, MEP and Fabrication V3.7 (mainly on Revit 2022)
- Autodesk Forma (only on Revit 2022)
These were the typical problems
- Naviate Ribbon was completely greyed out except for Help even though you had an active license
- Naviate New Project didn’t show any Naviate templates
- Custom Families in Electrical didn’t show any 2D families from cloud
This hotfix includes a newer version of the common dll (System.Text.Json.dll) which has been tested to work well with many other add-ins.
NOTE! Other add-ins loaded before Naviate might load another version of a common dll that can cause issues. Add-ins loaded after Naviate might stop working if they don’t support the loaded version of the common dll. Changing the order that Revit loads add-ins can be a way to solve those issues. Revit load the add-ins in alphabetical order of the .addin files.
