Naviate Structure release 2022.1.1
News include an easier install process, a new user login, a new licensing system and Rebar Numbering UK.
Naviate Structure notes
Rebar Numbering UK
Reinforcement of each partition is sorted by Member (structural member/host in which the rebar is located).
It is now possible to sort, number and export reinforcement that belongs to the same Member.
Member name and number of members is show for each partition, Member is populated from Host mark and Number of members is showing value from Host count parameter.
First, we show how many rebars are in one member (No in each) and Total number is presenting the sum of rebars for all equal members (No in each multiplied with No of members).
Naviate Accelerate notes
Easier install
Simplified install of Naviate applications.
We have made following changes
- Each Naviate 2022 application has one install file, Naviate “N” 2022.msi.
- We have removed the need to enter user or license information when installing.
- There is no longer a country specific “content pack” installed for each application. Content such as Families and Project files with system families are now only available through Cloud Browser tool within Naviate. Project Templates are available with Naviate New Project tool. Configuration files like shared parameter files, DWG Export configuration files, Keynotes tables and Assembly Codes are installed with Naviate applications and can be found in the C:\ProgramData\Symetri\Naviate folder structure.
- The install no longer updates the Revit.ini file. This means that you will not lose any personal settings that you have made in Revit when installing Naviate.
- All general tools included in Naviate Architecture, Electrical, HVAC & Plumbing, Landuse, Structure and Site & Landscaping is now placed in a separate application, Naviate Accelerate (Naviate AC). The Naviate AC applications is included in the install of those application. But it can also be installed as a separate application.
- All applications install an application named Naviate Help (Naviate HE) that contain the common Help tools.
- Both Naviate AC and HE can be updated and uninstalled separately.
User login
We introduce Symetri User ID for authentication when using Naviate 2022 applications.
A Symetri User ID is needed to run all Naviate 2022 applications except for Naviate Rebar Extension.
Create a Symetri User ID
- You can create a new account when you are asked to log in.
Naviate licensing system
Single-user license
- The single user license is personal.
- It can be used off-line once activated.
- The offline period is maximum 1 month without need for being online.
- You can have the single user license activated on two computers, but you are not allowed to use them simultaneously.
- It is possible to deactivate the license on computers and active on other computers.
- The license is time-restricted based on your contract and is automatically updated when renewed.
Multi-user license
- All users assigned to the license share a pool of seats.
- A seat is taken from the pool when you run a Naviate tool for that application (or when running a tool in Naviate Accelerate).
- If all seats are taken by other users, you will not be able to run the tool until a seat has been returned to the pool.
- A seat is returned when ending Revit/Naviate or when logging out from Naviate.
Trial license
The Symetri License portal is a web application that you can start from Help ribbon in Naviate or by using the link: https://license.symetri.com. Use your Symetri User ID to sign in.
As a standard user you can
- See started trial versions
Read more about how to manage your licenses here.
Improved Ribbon
Re-worked and renamed the Naviate Ribbon to reduce clicks to find and start Naviate tools
All general tools included in Naviate Architecture, Structure, Electrical, Site & Landscaping, HVAC & Plumbing and Landuse have got an updated Ribbon menu named [N] Accelerate (was called Naviate).
We have made the following changes
- Placed frequently used tools as buttons in the Ribbon panels instead of as an item in a pull-down list
- Use Split buttons instead of some short pull-down menus that allow starting the first tool directly without open the pull-down menu
- Remember last used tool for some split buttons where applicable
- Replaced some long pull-down menus with a button to activate a separate Ribbon for those tools
- Divided the Ribbon into smaller panels for better experience when resizing Revit UI
- Removed the Fire & Acoustic tools
Where is my favourite tool?
Separate application
The tools in [N] Accelerate Ribbon are still included in the applications mentioned above but is technically an own application called Naviate Accelerate. Naviate Accelerate is automatically installed with Naviate Architecture, Electrical, HVAC & Plumbing, Landuse, Structure and Site & Landscape and use those licenses as before. But it can also be can be purchased and installed separately.
If you for example have bought and installed Naviate Architecture, the Accelerate application is also installed and you can run all tools on your Architectural license. But when updating or uninstalling Naviate the Accelerate applications is a separate application. The is also the case for the Help tools that are included in all applications; it is technically a separate application but included in all Naviate application.
Quick PDF Export
Export current view or sheet, a selection of views or sheets or a complete sheet list with a few clicks.
The new tool creates PDF files for current selection using the selected PDF Export setting. Similar to Quick Print you can preselect a number of Sheets or a Sheet list in project browser and start the tool. But Quick PDF Export also allow pre-selection of views or a view list. If you start the tool without pre-selection the current sheet or view will be printed.
Select what PDF Export setting to use and file location or name. PDF Export settings are configured in the PDF Export tool found in Export tab in Revit File Menu.
Publish PDF-files
Configure Publish to export PDF-files without using a PDF-printer driver.
You can now configure PDF Exports in Publish that let you create PDF-files directly without the need for installing and configuring a PDF printer driver. You have the same option to select what Sheets or Views to export as you have when printing, a Sheet Set, A Sheet or View Schedule or by using a specified parameter & value.
Filter Elements using Type Name parameter
Use Type Name parameter to find and select elements using Filter Elements.
- We have changed the way some Naviate Tool save data in the projects to improve performance and avoid “There was an error generating the XML document” issue that could occur occasionally in individual projects.
