Naviate Daylight release 2022.1.1
News include a new user login and a new licensing system.
User login
We introduce Symetri User ID for authentication when using Naviate 2022 applications.
A Symetri User ID is needed to run all Naviate 2022 applications except for Naviate Rebar Extension.
Create a Symetri User ID
- You can create a new account when you are asked to log in.
Naviate licensing system
Single-user license
- The single user license is personal.
- It can be used off-line once activated.
- The offline period is maximum 1 month without need for being online.
- You can have the single user license activated on two computers, but you are not allowed to use them simultaneously.
- It is possible to deactivate the license on computers and active on other computers.
- The license is time-restricted based on your contract and is automatically updated when renewed.
Multi-user license
- All users assigned to the license share a pool of seats.
- A seat is taken from the pool when you run a Naviate tool for that application (or when running a tool in Naviate Accelerate).
- If all seats are taken by other users, you will not be able to run the tool until a seat has been returned to the pool.
- A seat is returned when ending Revit/Naviate or when logging out from Naviate.
Trial license
The Symetri License portal is a web application that you can start from Help ribbon in Naviate or by using the link: https://license.symetri.com. Use your Symetri User ID to sign in.
As a standard user you can
- See started trial versions
Read more about how to manage your licenses here.
