Naviate for Civil 3D version 2022.2 is now available for versions 2019, 2020 and 2021
All news and improvements that are available in 2022.2 version are now included in the previous versions too.
Naviate for Civil 3D is now updated for versions 2019, 2020 and 2021. All news and improvements that you can read about below for 2022.2 version are now included in the previous versions.
- Naviate for Civil 3D General 2022.2 release news
- Naviate Pipe 2022.2 release news
- Naviate Road 2022.2 release news
- Naviate Landscape 2022.2 release news
- Naviate Traffic 2022.2 release news
We also published an updated version of 2022.2 with the following commands and bugfixes. These are also included the previous versions.
New! Copy Existing SignHolder
“Hidden” new command to copy an existing SignHolder and signs to a new position. Not in Ribbons yet!
New! Set Traffic Surface for multiple Markings and SignHolders
“Hidden” new command to set “Project to Surface” for multiple Markings and SignHolder. Not in Ribbons yet!
Bug fixes and improvements
- Added the option to Select Similar when adding Property Data with Plant Data and Data Manager
- Column Size is now remembered in Plant Data and Data Manager
- Add Properties to Line and Add Properties to Point now highlights objects that have had propset applied
- The calculations in Simple Trench updates if Dynamic Update is active
- Multiple 3DPolys from Pipe Network now works if Pipe to structure Edge has been used
- NVPIpeNetworktoDWG skips question Export Lines, the option “None” is included instead
- NvPipeNetworkToDwg: Fixed an issue where Null Structures where exported as 3D Solids. Function now skips any structure with style where Model=Off
- Pipe to Structure Edge can maintain Elevation or Slope on the modified pipes
- GetVal Polyline.3DArea now supports varying Z-value on the 3Dpolylines
- Import List Definition can remove existing List values when importing a list that is already in the file
- Fixed an issue where Area Markings was created wrong for a counter clockwise pline
- Fixed an issue where Area Markings was not working on a copied AreaMarking-polygon
- Added ability to set 90 degree-corners for Cross Markings. New Setting added!
- Area Markings Angle now works ok for negative values as that earlier caused errors in the pattern
- Update Traffic Markings now also updates Lane Markings in 3D
- Sign Holder Manager - Create Variant no longer loses contact with SignHolder Section View
- In Insert Sign Holder "3D" toggle setting is now saved to next time you enter dialog
- In Sign Holder Manager, Status layers are now created if they do not exist!
- Fixed an issue where Normals of 3D-markings was sometimes wrong, causing Infraworks to display them in greyish-color and not cast shadows
