Naviate for Civil 3D 2025.2 Pipe release
Updates in Naviate for Civil 3D. Highlights include features Create polyline from Pipe Solid and Export and Import Parts list, as well as updates to Network Branches, Pipe Bend and Pipe Fillet and a fix to Simple Trench.
Changes are available in Naviate for Civil 3D 2025.2, 2024.12, 2023.22 releases.
Create Polyline from Pipe Solid
Creates a polyline from a selected point on a circular or egg-shaped solid. If the line is created from bottom or top, wall thickness can be added to place the polyline at Invert or crown. The created polylines can then be used with Create Pipe network to recreate a pipe network.
Two commands to export parts lists to Excel for ease of assigning styles, layers, materials etc, and then import them into a template or drawing.
Network Branches
Network Branches is a new term used for pipe spans connected with a spanning label. In the Object Explorer, commands such as Modify Pipes, Create Alignment and Rename parts can be started from a specific branch, thus the time spent selecting objects is significantly reduced. For commands that require a selection, Select by Spanning Label can be used to select the pipes/structures.
Pipe Bend
Pipe Bend has been updated to add Spanning labels and Property Set for quantification. You can now use a template for ease of creation, and you can create your own templates. Pipe Bend now has a break option for inserting a Tee in the middle of a pipe.
Pipe Fillet
Pipe Fillet can now edit an existing curved pipe.
  • Simple Trench has gotten a big performance boost and is now significantly faster in the calculation process.
All products in the release
