Naviate for Civil 3D 2024.3 Road release
Updates in Naviate Road for Civil 3D. Highlights include Updates to Copy Corridor, Extrude and 3D Measure plus a modified Subassembly for rock cut.
Changes are available in Naviate for Civil 3D 2024.3 release.
Subassembly
There is a new subassembly DaylightRockCutB_NV that has a horizontal rock shelf instead of “follow surface”. Either use NvSubassembly to insert it or to change an inserted DaylightRockCut_NV subassembly use Properties window and change .Net Class Name to DaylightRockCutB_NV.
Copy Corridor
Copy Corridor now copies Overrides and Transitions.
Extrude
Extrude can now support templates. When a template is saved, you get the option to save a description file. It can also create multiple Extrudes in the same command, and a Copy option is available in Edit. Also has a Preview. The command can also apply IFCExport to prepare for IFC Export.
3D Measure
3D Measure can now support templates. When a template is saved, you get the option to save a description file. The command has been updated with options to place blocks at Start/End of the line. It can also insert other blocks at the start/end to support for instance railings that have a start-segment and end-segment that is different from the main railing. Also has a Preview. The command can also apply IFCExport to prepare for IFC Export. The command now supports MVBlocks as well as Note-labels.
- Corridor-Solids (NvCorShapeToSolid+NvCorLinkToShapeSolid) now uses 0.01’ in Imperial dwgs
- Update Feature Line Label Group - now reports when alignment is missing and allows change to existing alignment
Other products in the same release
