Naviate for Civil 3D 2024.3 Landscape release
Updates in Naviate for Civil 3D. Highlights includes updates to Edit Elevations, Extrude, 3D Measure, Object Styles and Create Sub Surface.
Changes are available in Naviate for Civil 3D 2024.3 release.
Edit Elevations
Edit Elevations By Scroll and By Values support Pickfirst.
Extrude
Extrude can now support templates. When a template is saved, you get the option to save a description file. It can also create multiple Extrudes in the same command, and a Copy option is available in Edit. Also has a Preview. The command can also apply IFCExport to prepare for IFC Export.
3D Measure
3D Measure can now support templates. When a template is saved, you get the option to save a description file. The command has been updated with options to place blocks at Start/End of the line. It can also insert other blocks at the start/end to support for instance railings that have a start-segment and end-segment that is different from the main railing. Also has a Preview. The command can also apply IFCExport to prepare for IFC Export. The command now supports MVBlocks as well as Note-labels.
Object Styles
Object Styles can now create a text style if needed. Create and Update Table/Label - can now create a leader along with the label. It also has a text height option that will be maintained after update. When Updating the label, the placement of the schedule and leader can be updated in tandem or individually.
Create Sub Surface
Create Sub Surface now has settings for how dense the slope to surface points on the datum surface should be created.
  • Slope Arrow now uses the layers from Drawing Settings in the file. The command also imports the necessary labels from the Naviate template if needed.
Other products in the same release
