Naviate for Civil 3D 2024.3 release
Updates in Naviate for Civil 3D. Highlights include the feature Objects On/Off, update to Property Set Import, Create and Update Table/Label and Create View Frames.
Changes are available in Naviate for Civil 3D 2024.3 release.
Objects On/Off
Network On/Off has been reworked to include Surfaces, Alignments, Corridors and Featurelines. It also is available on the right-click menu for the objects that are supported. The Objects On/Off palette can dock with the rest of the Naviate Palettes
Property Set Import
Property Set import now imports PropertyDataFormat.dwg to maintain the dataformats in the Property Sets.
Property Functions now support other signs in the CSV-files, such as , ; ‘ ‘’.
Create and Update Table/Label can now create a leader along with the label. It also has a text height option that will be maintained after update. When Updating the label, the placement of the schedule and leader can be updated in tandem or individually.
Create View Frames
Create View Frames now sets text height for schedule in relation to the entered size and scale in your drawing. Same function now allows you to select an existing text-object to set the Layout_Number when adding the NvViewFrame Property Set to existing View Frames.
  • Profile Setup now unloads its CUIx to avoid duplicate Naviate-tabs
  • Profile Setup supports a user-based installation of Naviate
  • Naviate Palettes can now be docked
  • Create View Frames can now set text height for schedule in relation to the scale in your drawing
Other products in the same release
