Naviate for Civil 3D General 2022.3 release
Updates in Naviate for Civil 3D General. News and improvements include; the new features add property to set objects and export property data to CSV.
Changes are available in 2022.3, 2021.13, 2020.23 and 2019.33
NVPropSetAutoADD
A new scriptable command that adds property set to objects.
NVPropsetDataToCSV
A new scriptable command to export property data to CSV.
Property Set function GetVal
Now supports * instead of object type. For example use {GetVal[*.Name]} to get name for all objects the property set is placed on.
Dynamic Update of Naviate Property Data (NVPropUpdate)
The Dynamic Update now automatically excludes certain commands that have been noticed to cause issues, such as NVCorShapeToSolid. The commands are listed in an Exclusion-file that is stored under Program files.
The Dynamic Update only updates property sets placed on objects that are listed under Applies to in the Property Set. E.g. if a property set is moved from a Pipe to a Solid, the information remains static on the solid while it updates on the pipe.
Add Properties to Lines (NVPropAddToLine)
Now supports selection of Property values to set for selected Property Set. Also now supports getting 2Dlength, Start/End station and Extrude-Profile-Name for solids created with Extrude along path.
Add Properties to Points (NVPropAddToPoint)
Import Naviate Styles (NVImportStyles)
Fixed an issue where the command failed to find the Naviate template for certain languages.
Import KOF/Sosi/TiT/Nyl
The commands were lost and have now been found – you can find them under In / Out on the Naviate-tab.
