Don't miss out
Want to see the latest Naviate for Civil 3D General news?
Updates in Naviate for Civil 3D General. News and improvements include; Duplicate Property Data, Remove Propset, Property Palette, Match properties from CSV, and Extract Faces.
Changes are available in 2022.2.
For scripting: NVPropDataDuplicate. Copies Property Data from e.g. a dynamic Property Set (which is already on the object) to a Non-Dynamic Property Set (which is added to the object) for selected objects.
Removes Property Set from multiple objects or all objects.
Can now view and export only the select properties.
Added the possibility to save a settings file that saves what CSV-file to use and what properties to match between. Also added the option to select a delimiter.
Extracts Boundary as well as 3D Faces and can optionally not extract 3D Faces.
Added Structure.PipeLowerInvertElevation and Structure.PipeHighestTopElevation as valid information points.
Added the option to use a selected delimiter.
Now places Support folder under _Shortcut in project, this change was made to make BIM360 support Naviate Naviate Support Folder updates.
Added to NVImportAssembly and NVVerifyAsembly. If Refresh Data Shortcut Project is ticked, it means that RefreshDataShortcutProject will be run before NVImportAssembly dialog opens, to force Civil to Refresh all DataShortcutProject including Assemblies-NV and Naviate Support e.g. in BIM360!
Fixed an issue where the command didn’t update when using multiple regions.
Fixed an issue where the subassembly name wasn’t added to the property set.
