Naviate Fabrication May release 3.9
Release news for Fabrication. Improvements includes updates to Solving Data Conflicts between projects, the What's New Pop-up, Data Flow, Spool Manager Options overhaul, Spool Manager Titleblock Sheet Parameters, Rehost, Naviate Filters Support for 2019-2021, Trapeze Support Adjust vs No Adjust Insulation
and fixes.
Please note: Naviate MEP and Fabrication are now available for Revit 2019 through 2025
What's New Pop-up
Data Flow
Data Flow is a new command that customizes how Revit parameters and properties are synchronized, leveraging Powershell scripts.
After opening the command from the [N] Fabrication tab (1), the Data Flow main dialog is split into two tabs:
- Conditions (2)
- Scripts (3)
The Conditions tab is the manager for all the Conditions in the project. Conditions can be grouped into user-defined Groups, and when selected, that Group will display all contained Conditions in the Conditions Window (5). Under Condition Groups (6), separate Groups can be created to better separate and organize the list of Conditions. Lastly, Conditions can be imported and exported, also including any associated Naviate Filters and Scripts contained in the Condition.
Conditions can be executed automatically or manually by setting the Execution Type to the following options:
- Auto: Condition is auto executed on Element Creation and Element Update
- Element Creation: Condition is auto executed when a new Element is created in the project
- Element Update: Condition is auto executed when an existing Element is modified in the project
- Manual: Condition is only manually executed, by clicking the associated Play button
Selection Override (7) gives more selection flexibility to which Elements in the model are executed. Instead of gathering the to-be-executed Elements by Naviate Filter, Selection Override will allow selection based on a Preselection, Naviate 3D Zone, Elements in View, and All Elements in the project.
The Scripts tab (1) is the manager for the Powershell Scripts that are loaded into the Revit project.
Powershell Scripts are listed on the left-hand palette, where scripts can be imported, exported, renamed, deleted, and added. Scripts can also be tested for their return value with the ‘Test Script’ button (3). Once this button is clicked, you will be asked to select a Revit Element. The script will execute, with the returned value being displayed in another window.
Finally, the Script Editor (4) is a simple text editor to view, create, and modify Powershell scripts. These scripts will then be assigned to a Condition in the ‘Conditions’ tab.
Spool Manager Options has been refreshed to allow multiple 3D Views and Schedules to be configured and placed onto Spool Sheets.
Additionally, placing Views onto Spool Sheets have an improved and more flexible functionality. Similar to [N] Accelerate’s – Sheets & Views – Place Views command, placing Spool Views can now be placed in the different 9 locations of the Sheet (Top Left to Bottom Right, and all in between).
Preset Titleblock/Sheet Parameters on creation or batch edit existing Spool Sheets.
In Spool Manager, Titleblock Sheet Parameters can be viewed and configured by clicking the right-hand arrow (1). The Sheet Parameters dialog will expand to the right of Spool Manager.
Clicking the Spool to the left will inherit any values in the Selected Sheet Parameters tab to the right. If entered values wish to be locked or not changed – to set for other sheets – the ‘Lock Values’ check box can be enabled.
Once the desired values are set, clicking Update Sheets will execute on the Sheets that are checked in the main Spool Manager window.
These Selected Sheet Parameters and values can be imported and exported as well between projects (or within the same project as a separate Save or backup).
Rehost
Rehost includes commands to move and reconnect Taps, OLETs, and MEP Fabrication Hangers to a selected MEP host. Rehost contains two commands:
- Fab Rehost: existing unhosted Taps, OLETs, or hangers are selected. Then select the branch or main. The Tap/OLET/hanger is then moved, aligned, and most importantly reconnected to the branch/main.
- Copy Rehost: choose an existing Tap, OLET, or hanger. Then select the branch or main. The Tap/OLET/hanger is copied, aligned, and most importantly reconnected to the branch/main.
[N] Accelerate's command now has support inside of [N] Fabrication 2019-2021.
Accelerate is only available for Revit versions 2022 and forward. The Accelerate features for versions 2019-2021 are currently available in [N] Core, which does not include Naviate Filters
3.9 contains a Naviate Filters command for versions 2019-2021 only within Fabrication. For Revit versions 2022 and forward, ensure Accelerate is installed to use Naviate Filters.
Trapeze Commands now support ITM Parts with 'Adjust' or 'No Adjust' Insulation Specifications.
For 'No Adjust' Insulation Specifications, Trapeze commands will place the hanger at the bottom of the MEP Fab Straight.
For 'Adjust' Insulation Specifications, Trapeze commands will place the hanger at the bottom of insulation.
- Multi-Shape Taps Error
- Fixed issue when a multi-shape tap is opened with the Fabrication Properties window.
- Tag All
- Fixed issue where the command would disregard Subcategories.
- Tag Settings
- Fixed issue where a tag would place incorrectly for vertical elements.
- Tag Shortcut
- Fixed issue where the Tag Shortcut List does not update properly when switching between multiple projects.
- Sleeve Placement
- Fixed issue with "Rotated" Rectangular Ductwork placing reversed-sized Sleeve.
- Hanger Rod Extension
- Command now can attach to the 'Generic Model' Category but ignores RFAs containing the string 'Points'.
- Blockout Sleeves
- Fixed issue where Duct Accessory Sleeve was default Sleeve placed for all Categories.
