Naviate Electrical October Release 2023.1.13 and 2024.6.1
Release news for Naviate Electrical. Highlights includes new download from MySymetri, new check for updates, updated Symetri login, updated Symetri licensing and Create Circuit.
Check for updates
Get notified if there are newer versions available for download. When Naviate is started there is a check if there are newer versions available of your installed applications.
Updated Symetri login
Updated Symetri licensing
Create Circuits
Allow users to create circuits from multiple elements for each selection.
A new command has been added the Naviate Electrical toolbar which creates a separate circuit for each electrical element in a selection.
When users click the Create Circuits button, they will be prompted to select elements with an Electrical Connector. The selection is intended to include multiple elements.
This command is especially helpful when circuiting several mechanical or plumbing equipment elements that require a dedicated circuit. When the user has finished selecting elements to circuit, click ‘Finish’ in the Options Bar.
Then, the user will be prompted to select the panel in which all the elements will be circuited to.
A message will appear noting how many circuits were created in the process.
Finally, you will see that the Panel Schedule will show the dedicated circuits for each element.
- Electrical XML Link. Resolved an error in projects where equipment is not set
- Circuit Tools. Revit will now throw a Naviate message explaining the user error if the commands are unavailable versus the Revit API exceptions
- Copy Circuits. Resolved an issue where the tool would not copy elements on vertical walls
- IFC Space Copy. Updated to now remove spaces only when reloading existing links
- Export Wire Data. Fixed template folder pathing and added error message to Wire to Excel tool
