Naviate Electrical December Release 2025
Release news for Naviate Electrical. Highlights includes new download in MySymetri, new check for updates, a separate install for Naviate Accelerate, help in each application, updates to login and licensing.
Check for updates
Help and Support is now located in the Accelerate tab and links will point to the associated Pinnacle Help pages.
Naviate help pages are now hosted on Pinnacle Series, a learning platform that contains user manuals, explanations, courses, learning paths, and step-by-step instructions for Naviate commands.
Note: Users can access the Help page of any Naviate command by pressing F1 on their keyboard when hovering with their mouse pointer on the desired command.
Updated Symetri login
Updated Symetri licensing
Circuit Tools: Revit will now throw a Naviate message explaining the user error if the commands are unavailable versus the Revit API exceptions.
Copy Circuits: Resolved an issue where the tool would not copy elements on vertical walls.
IFC Space Copy: Updated to now remove spaces only when reloading existing links.
Remove Circuits: Handled removing elements with multiple connectors with a Naviate message.
