Naviate Daylight September Release 2025
Release notes for Naviate Daylight. Highlights includes support for Lux and Foot Candle Calculation and new download from MySymetri.
Check for updates
Updated Symetri login
Updated Symetri licensing
If you have rights to manage licenses on My Symetri there is now an option to create a license file including Single user licenses that you can copy to machine not connected to internet.
A zip-file is generated and downloaded by the browser. Extract the included license files and copy them to the %appdata%\Symetri\Licensing folder on the machine you want to use off-line when you are logged in as the user specified when creating the license file.
Lux and FTC Unit Support
Calculation of Daylight factor now includes Lux and Foot Candle. Run the daylight factor calculation as usual and they will be included in the calculation window.
