Naviate Daylight October Release 2023.1.7
Release notes for Naviate Daylight.
UX/UI Improvements
Updated user interface to new Naviate look & feel.
We have made the following improvements:
  • Updated our dialogs to be streamlined with the Naviate look & feel
  • Provided better overview of Design Suggestions (Comments)
Daylight Factor & Daylight Ratio
  • Provided possibility to run multiple Factor & Ratio calculations and compare results
  • Improved  overview and control of results by providing separate dialogs for Factor & Ratio calculations.
    • You can run Daylight Ratio and/or Daylight Factor calculations independently
    • Seperately generate reports and visualizations for each calculation
Daylight Settings
Improved workflow by enabling you to configure the settings without having to run the calculations first.
Report
Improved & updated standard-specific report templates.
Now we will document the area values with more precision, without rounding up the values. Each Area parameter will be documented with two decimal precisions.
