Naviate Accelerate is part of this release
Don't miss out on the Naviate Accelerate that is part of this release. You will need to download both seperately. Read the Naviate Accelerate news here.
Release news for Naviate Daylight. Highlights includes an update on What's New pop-up and fixes to Daylight Factor and Daylight Ratio.
