Naviate Daylight December Release 2022.1.6
Updates in Naviate Daylight. Highlights include Daylight Ratio and Daylight Factor.
Naviate Daylight is only available on Revit 2022 and 2023 platform
Changes is available in version 2022.1.6
To be able to update Naviate applications to version 2022.1.6 , you need to manually download and install the update from our download page. Remember to update Naviate Help and Naviate Accelerate as well. All installed applications must be updated to 22.1.6. Find more information here.
Daylight Ratio & Daylight Factor
Elements from Revit links are now included in Daylight Ratio and Factor calculations.
You can now Link surrounding buildings and toposurfaces to your host project as Revit links. Elements will be considered when calculating Daylight Ratio correction factors and when calculating Daylight Factor values.
- Daylight Factor: Fix issue when exporting complex geometries to Radiance
- Daylight Factor: Fix issue with Rooms that have varying Floor height
- Daylight Factor: Fixed issue when reporting Wall Offset and calculation point distance in Word report
- Daylight Factor: Fixed issue when defining calculation height on Rooms
