Naviate Bimfire September Release 2025
Release news for Naviate Bimfire. Highlights includes new download from MySymetri and fixes.
Check for updates
Updated Symetri login
Updated Symetri licensing
- Audit Trail - Accept changes in Audit trail now only accept the location for one change. Earlier the accepted family was permanently accepted.
- Audit Trail - Audit trail has been updated to how it finds changes. Earlier you could not move the requirement symbol without triggering Audit trail.
- Connect Spaces - Connect spaces no longer connects spaces to rooms from a level below that stretches to the host level.
- Quick Family Connection - Quick connection now rotates requirement symbols with openings, same as for opening requirements.
- AutoConnect Requirements - Auto connecting requirements now clears all Bimfire parameters if the connection fails.
- Disconnect Family - Disconnect family now resets all Bimfire Parameters.
