Naviate Accelerate is part of this release
Don't miss out on the Naviate Accelerate that is part of this release. You will need to download both seperately. Read the Naviate Accelerate news here.
Release news for Naviate Bimfire. Highlights includes an update to What's New pop-up and fixes to Wall Connection.
