Naviate Bimfire January Release 2023.1.9
Release notes for Naviate Bimfire. Highlights includes easier access to help and e-learning and IFC mode.
IFC Mode
New feature which supports selecting walls & openings and creating compartments from IFCs exports from ArchiCAD. Enabling data transfer from IFC model to ArchiCAD model.
By turning on the IFC mode in the ribbon you will enable BIM Fire tools to work with IFC exports.
Main Features
- Create Wall compartments from IFC exports
- Create Opening compartments from IFC exports
- Connect symbols to elements from IFC exports
- Check changes made to connected underlying elements in the linked IFC
- Check that all requirements are connected to the correct object in IFC
