Naviate Architecture September Release 2025
Release news for Naviate Architecture. Highlights include new download from MySymetri, updates to Room Drawings, Create Zone Areas and more.
Check for updates
Updated Symetri login
Updated Symetri licensing
If you have rights to manage licenses on My Symetri there is now an option to create a license file including Single user licenses that you can copy to machine not connected to internet.
A zip-file is generated and downloaded by the browser. Extract the included license files and copy them to the %appdata%\Symetri\Licensing folder on the machine you want to use off-line when you are logged in as the user specified when creating the license file.
Room Drawings
The Room Drawings feature now supports pre-selection and can be run directly from the Modify tab. This means that when you run the tool pre-selected Rooms will automatically be checked in the Room Selection list.
Create Zone Areas
Improved placement of Area Boundary lines for Create Zone Areas and Zone Regions to accurately align with the Net Area.
Updates on Area Boundary Lines placement:
- If the adjacent Room is not part of any Zone, the Area Boundary Line will be placed along the interior face of the partition Wall.
- If the adjacent space is empty (no Room placed), the Area Boundary Line will also be placed along the interior face of the partition Wall.
- Rooms that contain cladding Walls will be part of the general Zone area and Area Boundary Line will be placed along the interior face of the partition Wall, without separating the main Wall from the cladding Wall.
- Door/ Window Drawings - Adjacent Doors and Windows are now automatically hidden in the views.
- Door/ Window Drawings - Schedule dropdown will now be grayed out when using Update.
- Opening Area - Fixed issue with NVCurtainWallArea calculations.
- Create Zone Areas - Fixed issue with Read-only parameters.
