Naviate Architecture September Release 2022.1.2
Updates in Naviate Architecture. Improvements to features such as create wall and ceiling coverings and improvements to door drawings.
Changes is available in version 2022.1.2
Create Coverings
Create Wall and Ceiling Coverings
You can now also create Wall and Ceiling Coverings for selected Rooms.
We have extended and improved the Create Coverings tool to be able to:
- Place selected Type of Wall and Ceiling Coverings based on the boundaries of the selected Room(s)
- Define their height and offset within the selected Room(s)
- Define if the Wall Coverings should be joined with the main Walls and at corners
- Choose to create Coverings around Columns within the Room(s)
Modify tab
The Create Coverings tool is also added to the Modify tab when Rooms are pre-selected in order to access the tool easier.
Door Drawings UX Improvements
Improved how we handle duplicated Type ID warnings.
The duplicated Type ID warning message is now showing a list of all Type IDs that are duplicated within the project.
Remark: In previous versions the tool was only showing the latest duplicated value and ignored the values that have been duplicated previously.
In addition; the tool will not close immediately after this warning dialog is closed and the settings you made in the main dialog are not lost.
- Create Zone Areas: Fixed typo in the Report
