Naviate Accelerate is part of this release
Don't miss out on the Naviate Accelerate that is part of this release. You will need to download both seperately. Read the Naviate Accelerate news here.
Release news for Naviate Architecture. Highlights include the two new features Room Finishes and Create Boundary Lines. The updates includes Curtain Wall Elevations, Door and Window Unique Identifiers and Drawings, changes for solving data conflicts and the What's New pop-up.
Transfer an element's Material parameters into a Room Finishes parameters in Revit.
With this new feature, you can transfer any element's material parameter into the room finish parameters in Revit (e.g. Ceiling Finish, Wall Finish, Floor Finish, & Base Finish). Additionally, you can include the total material area in the parameter and choose to write multiple element’s material layers if required.
Configure the settings in the Room Finishes Settings dialog before starting the tool. Parameters will be written as a Text parameter. Cladding walls in a room cannot be room-bounding, as they exclude walls or elements behind them from calculations. Only elements that are part of the room boundary will be considered.
Create and Update Area Boundary Lines using different Wall Types.
With this new feature, you can create Area Boundary Lines based on different Wall Types before placing Rooms in Area Plan. Lines are placed according to the Basic/Curtain Wall Functions (Interior, Exterior, Foundation, Retaining, Soffit, Core-shaft) and Placement Rules. You can also update Area Boundary Lines, ensuring all lines are recreated to reflect the latest wall changes. All lines will be created as unpinned Area Boundary Lines.
Create Curtain Wall Elevations using Elevation View type and add dimensions to all Curtain Wall types.
You can now create Curtain Wall Elevations using Elevation View Types. Additionally, if Dimensions are included, overall dimension lines will be correctly placed on all Curtain Wall Types.
Choose to include or exclude Sequential Numbering when a Room contains only one Door/Window.
Choose whether to include or exclude Sequential Numbering when a Room contains only one Door or Window. If you choose to exclude this parameter, all related definitions will be ignored.
Add a Start Sheet Number that increments sequentially.
Start Sheet Number option has been aligned with other Naviate tools. Sheet Numbers will now increment sequentially.
