Naviate Architecture June Release 2024.5.1
Release news for Naviate Architecture. Highlights include Descriptions, Door & Window Drawings, Slope Arrow and Fixes.
Descriptions
Improved tooltips of each tool by clearly explaining tools purpose and providing relevant instructions on how to use the tools.
Now, each tooltip provides you with information about
- Purpose of the tool
- Explanation of major functionalities of the tool
- “Quick” instructions on how to use the tool
- Remarks and notes about specific “hidden” options
Now you can include Curtain Doors and Curtain Windows in your drawings.
With this improvement, Curtain Doors and Windows are no longer filtered out and excluded from the drawings. Each Curtain Door or Window found in the schedule will now have elevations and plan views created and placed on the sheet.
Slope Arrow
Now you can use slope arrows which are compatible with Imperial Project Units.
We now provide you with a Slope Arrow which displays data in imperial units. Depending on the project unit settings, if they are set to either metric or imperial, we will identify the setting and based on that activate the appropriate Slope Arrow family when you run the feature.
- Create Coverings: Fixed issue when joining walls with Base offset.
- Export Rooms - Room Surface: Fixed issue when running tool in projects with room separation lines
- Manage Door & Window UIDs: Fixed issue with values being reset when changing filter settings in the dialog.
- Room Drawings: Fixed issue with duplicated views created by the tool.
- Room Drawings: Fixed issue with 3D View creation and placement on sheet.
