Naviate Architecture January Release 2023.1.9
Updates in Naviate Architecture. Highlights include easier access to help and e-learning, manage coverings, split element and more.
Manage Coverings
Manage coverings in Rooms by quickly identifying and removing specific coverings within selected Rooms.
Now you can know in which Rooms you have created Coverings, and you will be able to remove specific coverings. Then, using Create Coverings, you can recreate your Room coverings.
Main Features
- Shows each pre-selected Room in a list view (Room Name + Room Number)
- Shows which covering types are present in each Room
- Easily remove all or specific covering types from all Rooms
Split Element
Split Element is a new feature, earlier called Split Floor. Added support to allow you to efficiently split floors, roofs, ceilings, and toposolids.
Now you can easily split multiple building categories with one tool.
Main Features
- Supports pre-selection of split line and element
- Keeps sub-element points on shape-edited elements
- Keeps hosted elements after splitting (hosted model and detail elements)
- Supports elements with Slope Arrows
Room Drawings
Added the ability to create Room elevation drawings using elevation views.
Now you can create your Room Drawing Elevations using elevation markers.
You can specify both View Type and View Template for created elevation the same way as with Section View workflow.
- Door/Window Swing & Count: Fixed issue with counting "hidden" or "deleted" curtain door types.
