Naviate Architecture April Release 2023.1.10
Updates in Naviate Architecture. Highlights include improved Door & Window drawings.
Door and Window Drawings
Now you are able to use schedule filters and sorting/grouping in order to define which elements are included or excluded on the drawings.
Now you are able to update your drawings and keep manual changes on views and sheets after changing:
- Selection settings: Update schedule filter or sorting/grouping settings
- View settings: Update view templates, adding/removing dimensions on views, or changing view layout
- Sheet settings: Update titleblock, change sheet layout or sheet info.
Improved the display of the "Not in use" symbol and added ability to customize the symbol as desired. This allows you to customize the symbols for deleted doors to suit your visualization standards.
- Door & Window Drawings: Fixed issue when customizing "Not in Use" viewports.
- Create Coverings: Fixed issue when using the tool with Imperial Units.
